Latest post 07-01-2008 2:21 PM by Russ. 3 replies.
Page 1 of 1 (4 items)
  • 06-30-2008 8:37 PM
    • bjwtpa
    • Not Ranked
    • Joined on 06-30-2008
    • Clearwater Beach FL USA
    • Posts 2
    • Silver Member
    Beolab 2 - How can I turn it on to use with non B&O equipment
    Hello: What can I use to send voltage to pin #4 on the powerlink IN of my Beolab 2 to turn it on, and what is the maximum recommended voltage.
    Thank you.
    John
  • 07-01-2008 10:39 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Beolab 2 - How can I turn it on to use with non B&O equipment
    Hi John,
    this question come up a LOT...in the US, contact your local B&O shop and order part #898127.  $50 + tax & S/H.  Since it is not a part made in DK by B&O, they may have to jump through an extra hoop or two to get it for you, but they're available.  This gives you a dc power supply, and the connectors you need to make it work.  Let me know if you have any other questions.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 07-01-2008 12:12 PM In reply to
    • bjwtpa
    • Not Ranked
    • Posts 2
    • Silver Member
    Thank you Russ:
    I have ordered the part you suggested.
    I have since learned that depending on the component output going into the Beolab 2, an item such as a Niles Audio APC-2 might also be neccessary in addition to the 0898127 to sense that the component has been turned on or off and thereby controlling Beolab 2 appropriately
    John
  • 07-01-2008 2:21 PM In reply to
    • Russ
    • Posts 641
    Absolutely correct John.
     Good luck!
    Russ
    McLean, VA USA
