Latest post 06-30-2008 6:22 PM by auric. 2 replies.
Page 1 of 1 (3 items)
  • 06-30-2008 2:44 PM
    Correct Torx Drivers
    Hi:
    I'm located in the USA. Most things are imperial here.
    Does anyone know the right sized metric torx drivers that I need for the screws on the Beocenter 4000/Overture?
    Thanks,
    Derek
  • 06-30-2008 3:02 PM In reply to
    • camshaft
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Pennsylvania, USA
    • Posts 575
    Re: Correct Torx Drivers
    Hey Derek,
    Even though we're in the US, practically all the tools available at Home Depot, Lowes, and Sears are available in both metric and imperial, unless in your area things are different from where I am.  For about $10, those stores should have a 5-piece torx driver set, with sizes T10, T15, T20, T25, and T30.   Practically all B&O items use the T10 and T15 drivers.  Here's an example of the Lowes set:
    http://www.lowes.com/lowes/lkn?action=productDetail&productId=159650-930-324TX5C&lpage=none
    Austin
    -Austin (resident audiophile skeptic)
  • 06-30-2008 6:22 PM In reply to
    Cam:
    Thanks for the sizes. Just picked up T10 and T15 (double ended) driver by Wiha (German). It cost $13.
    There were much cheaper store branded ones but they looked like "stone knives" compared to the Euro stuff :)
     Thanks again for your help.
    Derek
