Latest post 07-01-2008 11:16 PM by Peter Jacobs. 6 replies.
Page 1 of 1 (7 items)
  • 06-30-2008 2:56 AM
    Essential difference between a BeoVision 4 50" versus the 65" ?
    Hi, can someone tell me the essential difference (if money was no object) between the 50" and 65" BV4 ? Please. Also I note that the BV 9 has a Beosystem 3 "built in" but it has an analogue tuner. However, does the stand alone Beosystem 3 used with a 50" or 65" BV4 have a digital tuner ?
  • 06-30-2008 7:42 AM In reply to
    Re: Essential difference between a BeoVision 4 50" versus the 65" ?
    Is this a trick question? Laughing Both are now full HD but the 65" is bigger!
    The Beosystem 3 can be specified with the combined DVB-S/T so the answer is yes.
  • 06-30-2008 7:53 AM In reply to
    • archie
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    15'' Big SmileBig Smile
    DU BEAU, DU BON, DU BO.
  • 06-30-2008 10:18 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    In the US, the BeoSystem 3 (in all forms) ships with both analog and digital tuners.
    PJ, when you have the time, I'd like to talk to you about this bridge I have for sale in NYC.  Devil
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 06-30-2008 10:03 PM In reply to
    OK - all you smartypants ! [:'(]I asked the question because I was told by a desaler that  the 65" had better "contrast technology" and the premium over the 50" was not just because it was 15" bigger. I believe it has a darker contrast coating.
  • 07-01-2008 4:15 AM In reply to
    Well, your dealer may be partially correct about the "Contrast Technology" in terms of the maxmium ratio. Both the 50" & 65" have the same electrical spec expect for PEAK contrast ratio which is 5000:1 for the 50" and 10000:1 for the 65"
    Having said that, the typical continous Contrast Ratio for both screens is 3000:1 as quoted in the B&O spec.
    Regards Keith....
  • 07-01-2008 11:16 PM In reply to
    Thanks Keith. Now I have to figure whether I go for the B&O Offered SAMSUNG SP A800B projector + Motorised Stewart screen + BS3 (using my existing BV5 for normal TV viewing) or the 65" + BS3 and not bother with a Projector set up.
     Decisions, Decisions !!
