Latest post 06-30-2008 6:00 AM by Bibi. 2 replies.
Page 1 of 1 (3 items)
  • 06-29-2008 12:05 PM
    • Bibi
    • Not Ranked
    • Joined on 06-13-2008
    • Posts 5
    Going digital and getting it all connected.....help please!
    Hi All,
     Please can someone help.
     I have a DVD1 and a Beovision Avant VCR which (thanks to Peter) I have successfully connected.  I now want to attempt to connect it all through my old Ondigital freeview box.... only problem is I haven't a clue where to start..... please can someone help?
     Thanks a lot
     Bibi
  • 06-29-2008 5:01 PM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Re: Going digital and getting it all connected.....help please!
    Hello!
    I'm affraid it is not possible, as the command orders from Avant to DVD1 will not pass through the freeview box.
    The "decoder" scart could be used, but you will only get a the composite signal from the box, which is not as good as the RGB available through the AV socket.
    There is a B&O accessory called "Expander". Check with your dealer, it could be a solution.
     Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 06-30-2008 6:00 AM In reply to
    • Bibi
    • Not Ranked
    • Posts 5
    Okay thanks I will check with B&O.
