Is there any way to stop an ouverture opening its doors every time a person goes near it? Without turning off at the mains !!!!
Thanks Sandy
Yes - there is a way to do this!
However, i've forgotten..
Anyone?
Lee
9 LEE: Yes - there is a way to do this!However, i've forgotten.. Anyone?Lee
OK Lee, at least its a start!!
Sandy
I think that this feature was introduced on the BS3000 and 3200 but the same command does not exist for the Ouverture/2300/2500. At least, it is not mentioned in my service manual!
Regards Graham
I will take that as a no then......
I think, this is the post You are looking for:
http://forum.beoworld.org/forums/permalink/19576/18849/ShowThread.aspx#18849
Unfortunately, I also think, that it will not work with Your system, but who knows, it worth a try :)
