If you buy a beogram 3000 or similar, always get the seller to take out the platter and put it under the record deck in the packaging.
The very first one i bought on ebay ended up with a snapped arm and broken stylus. The platter lifts out, so if the deck is turned upside down, it smashs everything to pieces.
I never got any money back, but that deck has fixed at least another 4 as i've robbed it for bits.
