Latest post 05-16-2007 9:39 AM by mbee. 6 replies.
Page 1 of 1 (7 items)
  • 05-09-2007 8:51 AM
    BeoVision 7 vs Sony Kdl40w2000
    I know this is a bit of an unfair comparison but i just have a few questions tha i simply cannot answer, my dad has a beovision 7 40" which i recently hooked up my ps3 via dvi to play hd games, i was simply blown away by how good the games looked, take into account that the beovision only supports upto 1080i, i was playing a game that was running at 720p and it was incredibly smooth, the attention to detail was amazing, after that experience i decided that i had to purchase a hd tv, after some reserach i made the decision to purchase the kd40w2000 which can handle resoulution of 1080p. Now i cant help but notice when i play the same game on my sony, if doese not look as good as the beovision, sure it does look good but its no way as smooth and sharp, i have tweaked the settings after much research on this site but still it does not look the same, also what i cant figure is that for some reason the icons are actually displayed smaller on the beovision which to me would indicate that its runner at a higher resolution than the sony Any ideas??
  • 05-10-2007 11:02 AM In reply to
    Re: BeoVision 7 vs Sony Kdl40w2000
    I am afraid it shows numbers are not everything. No idea about the icon size which I agree sounds odd, but the Video Processor will simply be better on the Beovision - probably costs a lot more as well! The Beovisions do seem very good at movement though the resolution will probably be better on the Sony in a static picture. Would be interested what it was like on the BV4-65" Laughing
  • 05-10-2007 12:07 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The BeoVisions are the best picture on the market! Shame you didn't get a chance to see the new BeoVision 8, similar picture quality to the BeoVision 7 (better in some respects), fantastic sound and design, and at a price which competes with higher end Sonys!
     Weekly top artists:
  • 05-15-2007 1:07 AM In reply to
    depends what you watch on it
    i have a 40w and on sdtv it IS poor , it's not designed for watching off air tv
    but on ps3 / 360 / hd-dvd / blu ray it's amazing
    and less than a 3rd the price of a bv7
    popgear is grate™
  • 05-15-2007 1:57 AM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Does it have an inbuilt amplifier en dvd-player as well?
    If not, you can't really compare the price....
  • 05-16-2007 8:46 AM In reply to
    since you can buy a perfectly good dvd player from the likes of toshiba for £100 and and amp from say , rotel or sony for less than £400 , even adding those into the equation and the 7 looks ridiculously expensive
    don't get me wrong , it's a stunning piece of kit and i've seen it in the flesh , the build quality wipes the floor with the sony , any sony
    just doesn't strike me as very good vfm now that lcd panels are all much of a muchness
    it was different in the days of crt , then bno stood head and shoulders above the rest
    popgear is grate™
  • 05-16-2007 9:39 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    The problem of picture quality you mention has little to do with the electronic (the common issues with electronics and full-HD signals are mainly video noise, color calibration...)
    The issue of EVERY 1080p LCD panel actually on the market is their very slow response time, which is comparable to 720p panels 3 to 4 years ago, and this issue is VERY visible with HD games, which moves very quickly, and so the slow response time makes the moving picture look less sharp than with a recent 720p panel.
    If B&O release a bv7-40 with a 1080p panel now, it will be affected by the same problem, I'm afraid. Maybe this will be solved in the next generation of panel.
