can you post details, I have it working. I.e. what source you are using, what port the IR connector is linked to, STB version ..... I am in the US, it worked out of the Box on the 32". Is "AppleRemote" the STB controller you selected? Mine is called "Ipod Remote". it works including fast scrolling.
Cheers
JK
