1st March February 2012
Latest post 09-28-2008 5:23 PM by ChrDH. 20 replies.
06-19-2008 3:23 PM
ChrDH
- Joined on 04-16-2007
- Denmark
- Posts 493
Have anyone else ordered light dimmers from innovus.dk ??
Hi there 2 weeks ago I ordered two lightdimmers from INNOVUS, but nothing happened. Have anyone else had any experience with them? I have sent a reminder to them, but no respond at all... br Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
Re: Have anyone else ordered light dimmers from innovus.dk ??
I got mine two weeks after ordered them. It was some months ago. One of them was broke. I sent a mail and they sent me another one with no cost. Everything was fine for me. I'm in Spain.
PhilLondon
- London
- Posts 2,545
ChrDH: 2 weeks ago I ordered two lightdimmers from INNOVUS, but nothing happened.
Same here, still waiting...
Ehlerz
- Joined on 04-17-2007
- DK
- Posts 510
Hi Christian I ordered 3 of the old lightdimmers but when they arrived, none of them worked. I send them all back an instead recieved 3 of the new version 2 dimmers. They work very well. Had some mail dialog with the team though. Just keep on writing them, your dimmers will show up eventually..
BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
pedrompinto
- Joined on 04-29-2007
- Lisbon, Portugal
- Posts 239
I also ordered a lightdimmer and faced some delay (several weeks), so i sent some e-mails without any answer. Due to that i just give them a call and i was told the the production was facing, also, some delay. So, you just have to wait a little bit more and your products certainly will show up.
Pedro
"Less is more"
BV7-40 MKII + BL7.2 + BL9 + BL3 + BS4 + BL4 + A9 + Earset 2 + 2 x Beo4 +
BeoCom 5
ChrDH
- Denmark
- Posts 493
I got mine 2 days ago, none of them are working properly. One of them switches on for a moment, then off and is out of reach, the other is working with IR, but not responding to touch... So they will go back to Innovus. Fortunately I live close by, so I'll probbaly drop then off my self. br Chr
B&Ola
- Posts 302
Before sending them back, try flip the plug in the wall outlet (or wires in the plug). They are sensitive for this so give it a try! I've had the same problem but now it works fine. /Ola
deaddruid
- Joined on 05-24-2007
- Malvern, Worcestershire
- Posts 247
Would anyone here care to comment on the physical fitting of these dimmers? In the UK, light switches normally fit over an 80mm pattress (square metal box sunk into the wall). I suspect that these dimmers may not fit over these too well! Mark
ChrDH
- Denmark
- Posts 493
B&Ola: Before sending them back, try flip the plug in the wall outlet (or wires in the plug). They are sensitive for this so give it a try! I've had the same problem but now it works fine. /Ola
Yes I tried that a lot of times, but it only worked the first time, then it still didn't respond to touch, unfortunately. br Chr
ChrDH
- Denmark
- Posts 493
deaddruid: Would anyone here care to comment on the physical fitting of these dimmers? In the UK, light switches normally fit over an 80mm pattress (square metal box sunk into the wall). I suspect that these dimmers may not fit over these too well! Mark
Hi It probably will not fit that well, you can see the dimensions here http://www.innovus.eu/index.php?id=130 br Chr
ChrDH
- Denmark
- Posts 493
PhilLondon
- London
- Posts 2,545
wtlc2zpx: Same here, still waiting...
Well... They have debited my account today, so I hope that this means that I will receive them soon. p.
ChrDH
- Denmark
- Posts 493
I have now got 2 new ones, they work fine regarding the finger-touch operation, but will not really respond to IR commands, irritating, I can only turn them off with my beo4, not turn them on. Anyone else had this experience? By the way they were really friendly and gave me 2 new ones right away (I am house-sitting near by the office at the moment), but that is not really making up for the product not working properly. br Chr
PhilLondon
- London
- Posts 2,545
We are sometimes moaning at the price of B&O, but at least their product, and especially the LC2s work for years... p.
Kokomo
- Joined on 08-21-2007
- Spain
- Posts 618
wtlc2zpx: We are sometimes moaning at the price of B&O, but at least their product, and especially the LC2s work for years... p.
That thought had crossed my mind also!
ChrDH
- Denmark
- Posts 493
Just to round things up, I have now tested the dimmers, and they work fine when operating them with the beo4 or bl1000. You can number them just like the lc1-2 and create lightpictures. The reception is not as good as the LC, but nearly there. Oddly though, it does not respond to the light command of a A9 keyring... aparently Innovus forgot to program it for that command. br Chr.
Ehlerz
- DK
- Posts 510
ChrDH: Just to round things up, I have now tested the dimmers, and they work fine when operating them with the beo4 or bl1000. You can number them just like the lc1-2 and create lightpictures. The reception is not as good as the LC, but nearly there. Oddly though, it does not respond to the light command of a A9 keyring... aparently Innovus forgot to program it for that command. br Chr.
Mine does???
Quim43
- Posts 1,030
The same for me, don't work with the keyring.
PhilLondon
- London
- Posts 2,545
As indicated above I had ordered 3 Smartdimmers from Innovus, and after a long wait I finally got them in June. Unfortunately none of them are working fine, the light is turned off after about 5 minutes. Has any of you got the same problem? Do you know if the more recent one have the same problem? p.
ChrDH
- Denmark
- Posts 493
Yep, I had the same problem with one of my first ones. I sent them back and got a pair for new working ones. It took time but they came, eventually. br Chr
Page 1 of 1 (21 items)
