Latest post 05-16-2007 11:32 AM by Kevin. 6 replies.
Page 1 of 1 (7 items)
  • 05-09-2007 3:56 AM
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Beocom 2000 very quiet
    Hi all, I have two Beocom 2000's both from 1986.
    One, which is purple and not a look favoured by my OH, sounds and works great.
    In comparison the black version is much quieter.
    Does anyone know if there is a common fault with these going quiet?
    Thanks for any help,
    Kevin
  • 05-09-2007 6:19 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Beocom 2000 very quiet
    We had the very same issue with one about a year ago Kevin.
    We had the speaker replaced in the handset, and it was fixed!
    Lee
  • 05-09-2007 8:20 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Ok thanks guys.
    It is quiet on speaker phone as well though which makes me wonder a bit.
  • 05-09-2007 8:57 AM In reply to
    I have a new one boxed up and will try this out and see if its the same.
  • 05-15-2007 10:41 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Managed to pick a cheap one up in the same colour and swapped the handsets working fine now.
    Can anyone tell me how to get into the handset of these phones? It looks glued.
    Thanks for all the help,
    Kevin
  • 05-16-2007 11:32 AM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Anyone?Cool
