Hi Ben,
In the 1999 B&O Accesories Catalogue, on page 13, are listed 2 RIAA Preamplifiers
1. Part 8002956 for the BeoMaster 3500/4500
2. Part 8001245 for the BeoMaster 6500/7000
Now, the challenge is to find one!
And then to upgrade the capacitors and OpAmp, and THAT will be an RIAA amp worth listening to!
Regards
Menahem
									    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
