1st March February 2012
Latest post 01-29-2009 4:43 AM by k984942. 12 replies.
06-18-2008 4:34 PM
pdoisy
- Joined on 04-17-2007
- Italy
- Posts 41
Hi Dave and welcome to the site. If you want to use the B&O link standard, you are linking data/audio with masterlink and data/audio/video with masterlink+coax. For the video, B&O uses multi-channel RF modulator which means the source emits PAL or NTSC signal on a specific frequency to be decoded only on the desired link set. Due to the type of signal and the decoding/coding operation, you will not have a HD signal (the output would have to be DVB broadcasting but B&O is not there yet). Also, Masterlink is analogue stereo. Boxes (transmitting decoded signal, not broadcast signal) like Sky, DVD, HDR, beamers can use HDMI, DVI, component or RGB interfaces for transmitting HD content. Non HD content can be transmitted through composite and s-video interfaces. For your PC, depends what you want to do. For music/video, you can use BeoPort with a coax to a dedicated video card: this way you can play mp3 from your computer to your B&O sets, listen music and video from a B&O set on your computer. I hope that helps.
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
For SD (Standard Definition) RF transmissions from the master "Link" output of a Beovision to the link rooms I suggest you use double screened CT100 or FT100 coax cable as below Example of pricing for this cable is HERE
Bulgarien
- Denmark, Vest Sjaeland
- Posts 201
One
of the world's probably best aerial cables is from Webroe states called WC100,
which uses air as isolator, it can now gets in different colors (WF100 is
the foam versionen where Fét stands for foam or foam isolator) Here the difference between a arial foam cable and air cable (Its a messy site , but I notice that its cheapest to order cut lengths), for example, costs 15 metres WC100 only about £ 150 including postage delivered to your door. The service is indispensable to UG and since England is an EU country, there is no problem with extra costs/tax Coax cables does not need to be colourless and sad anymore ! Including some examples of cable all of which belong to the best end of the scale, | Fig. Fig. 2: Different types of dielectric. Top left, foam dielectric used in type B cable. Top right, semi-airspaced used in type D cable. Bottom left semi-airspaced used in type C cable. Bottom right semi-airspaced used in type A cable. |
...........B&O ICEpower.............. Because everything else is a waste of energy!
k984942
- Joined on 11-10-2008
- London, UK
- Posts 194
For a short indoor connection between TV's is there any benefit in buying some of the super expensive IXOS or QED coax cable, or would the Maplin cable Keith suggested above suffice?
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
k984942:
I would happily buy the cable recommended by Keith. Anything more expensive is likely to be a waste of money.
StUrrock
- Joined on 02-04-2008
- Cambridgeshire
- Posts 219
Do yourself a favour and run a Cat5e network at the same time !!!!! Also consider the following uses of cat5e cables:
Cat5e can be used to carry HD signals.
Then again Cat5e can be used to carry virtually anything you like and is v cheap..................
masterlink has done us proud but is on its way out......................
Dave
- Brisbane, Australia
- Posts 2,328
Umm regarding the cables insulated with air, AIR is not a screen against electromagnetic interference! What a load of cable hoop-lah
People who spend that much (150 pounds for 15m) on cables make me want to cry
Puncher
- Posts 9,588
Dave:
It's not there to screen, it's the insulator between screens and core. The geometry of the cable gives it it's characteristic impedance.
k984942
- London, UK
- Posts 194
I'm not too technically minded. What would running Cat5 replace? The masterlink or the aerial cable?
What interfaces/adaptors would I need ?
DoubleU
- Joined on 05-09-2007
- Posts 866
Cat5e / Cat6 is for future purposes. At least for B&O though.
You can easily run all media content there is through one cable.
k984942
- London, UK
- Posts 194
But right now, to link Avants I'm better off with the traditional masterlink and RF cables?
Page 1 of 1 (13 items)
