Graham,
Thanks for the information. I did as you said. I grounded the Beogram TX2 to the back of the Beocenter 9500.
I connected the RCA cables from the TX2 into the RCA to 5pin Din connection that I purchased from B&O.
I plugged the five pin din into the back of the Beocenter into the Phono connection. The sounds is terrible. Not only is there a loud
hum, the output from the TX2 is weak.
Does my Beocenter 9500 have a built in preamplifier ?
Should I be using an outside preamplifier?
I thought there might be something wrong with my TX2. I recently had it serviced and when I plug it into the back of my
Beosystem 10 (which is a portable music system) It plays very well. It does not even require the ground to be connected.
This is very frustrating. I purchased the Beocenter 9500 so that I could have a system that could handle a turntable.
Any ideas?
Regards
Jim
