Latest post 06-18-2008 6:47 AM by tournedos. 1 replies.
Page 1 of 1 (2 items)
  • 06-18-2008 6:26 AM
    Adapting my pair of BeoVox 2702 speakers
    Hi...Just wondering if anyone knows if it's a straightforward process to use my Beovox speakers [vintage early 70s] with a Pioneer amp/receiver of similar vintage?  [I'm hoping so....!]
    Thanks, trampsterdave
    Filed under:
  • 06-18-2008 6:47 AM In reply to
    Re: Adapting my pair of BeoVox 2702 speakers
    No problem at all - but check the impedance ratings first, your speakers might be 4 ohm (should read on the back in the type label) and your amp might want at least 8 ohms. I'd expect it to accept anything between 4-16 ohms, though.
    If the speakers have captive leads and the DIN connectors are still there, you'll have to decide if you want to cut them off, or purchace / build adapter cables. The amp most probably has screw connectors. The original DINs would be handy, though, once you get a nice vintage B&O receiver to replace the Pioneer Big Smile
    And welcome to Beoworld!
    -mika
