Latest post 06-18-2008 3:36 PM by Doc. 3 replies.
Page 1 of 1 (4 items)
  • 06-18-2008 5:30 AM
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Can you remove (by accident) a STB from the PUC-list?
    Is it possible to remove (by accident) a STB from the PUC-list, of a BV7-40 mkIII?
    Mine is lost.......... It only shows: "unknown STB"
  • 06-18-2008 8:19 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Can you remove (by accident) a STB from the PUC-list?
    I've seen this before.  Try doing a 'hard reset' to the BV-7/BS-3.  Unplug mains power for at least 45 seconds, plug it back in and tur the TV back on.  Generally restores all settings and PUC data.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 06-18-2008 9:30 AM In reply to
    • Doc
    • Posts 585
    Thanks Russ!
    Will try that tonight. After the soccermatch Sweden-Russia; winner will be the next opponent of Holland!
  • 06-18-2008 3:36 PM In reply to
    • Doc
    • Posts 585
    Russ, it worked! PUC-list is complete again after a reset of 45 sec.
    Many thanks.
