my old Beosound 3000 (SW 1.2, small clamper) goes to my dealer tomorrow for a softwareupdate. It's required because I want to use N.Music with a Beoport.
Can anyone tell me what "features" my BS3000 will have except the N.Music-functionality? Does it get PIN-Code etc.?
Thank you for your help
As far as I am aware, there are no additional features other than N-Music/N-Radio. I don't think you get pin code protection.
Certainly, I have had 3000's with N-Music and no pin code protection.
Please let us know if I am wrong!
Regards Graham
When your dealer updates your Beosound 3000 it is likely to be updated to at least version 3.1 which provided quite a lot of changes as follows:-
With the addition of Version 2.0 brought the new functions of N.MUSIC and N.RADIO to be used with BeoLink PC 2/Beoport.
The next major version update was to Version 2.12 which provided the following key fixes:-
The final major release of software was Version 3.1 which provided the following major fixes:-
Regards Keith....
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
thank you for the detailed info! This is somehting I miss on B&O products, I think there would be so much "hacking" possible ;-)
What about the Pin-Code-Feature? How can I check IF I have this feature when my baby's back at home and how do I use it?
I'm so excited :-)
Good evening, so, my Beosound 3000 is back with version 2.x
There is NO Pin-Code-Feature but N.Music works now. I've just tested it with BMLink for Mac and the BS3000 shows artist or album name :)I'm going to check features as soon as it is connected to a PC for the music.
What scared me at first:
After plugging in the BS3000 the light just lit up for a second and then nothing happened ... after a few seconds the standby-indicator came up. Is that normal?!
I have a Beosound 3000 with serial no. 1554xxxx, currently on sw 2.0.
Is it possible to upgrade it to Software 3,1 (I would like to move my Beosound 3000 to a link room therefore I need Option 6)?
Or is there a limit by 2,12?
Besides the Software Update do I have to change other parts of the Beosound 3000 (like CD interface)?
Thank you for your help.
