I have a Beomaster 7000 which started to behave like that: once I turn it on, it sends a humming sound to one loudspeaker and immediately turns itself off.
If I disconect the loudspeaker, it works- display and etc.
So, finnaly only one channel is working !
It was used before with Beolab Penta and I had no clue that one of the channel is not working because the system is working fine when connected on Powerlink ! Now Penta are gone and I'll use passive speakers with the system...
 In case I use the headphones, the system it does not turn off - one channel is OK, the other has a humming...
Any help will be highly appreciated,
thanks
