Latest post 06-17-2008 1:15 AM by dylan. 1 replies.
Page 1 of 1 (2 items)
  • 06-16-2008 11:26 PM
    • rickc
    • Not Ranked
    • Joined on 03-19-2008
    • Posts 5
    beoplayer - how to disable
    I currently have beoplayer and beoport installed to facilitate Nmusic. The problem is I actually play CD's using Windows media player as it appears to be simplier to use especially when managing playlists.  When I turn my system on both Beoplayer and Windows Media player start up so I end up withh two tracks being played at once. Does anyone know how I disable the Beoplayer  so it doesnt automatically start when I select Nmusic. I cant uninstall as I need beoport to run  my computer through the B&O...
  • 06-17-2008 1:15 AM In reply to
    • dylan
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Perth, Australia
    • Posts 117
    Re: beoplayer - how to disable
    I think you need to set up "PC" as a source on the beoplayer then select this - this will allow you to run media player but send the music out to your B&O kit.
    Dylan
    BS3200 BV7 BV3 BL8000 BG4000 BL4500 PC2 BG5500 MX4002
