I cant really say if I use quality RCA leads (define good), but since the speakers were stored for a while the inicial hum might simply be from dirt. Although I seriously doubt that simply cleaning the leads will stop the loud humming when I hook up the speakers to the stereo.
The stereo is a sony LBT-D307, the jacks on the back are the following:
-----IN-----
RCA (red and white) PHONO
RCA (red and white) CD
RCA (red and white) VIDEO
-----SPEAKERS-----
Traditional or older simple wire clipping system (dont know the name). Where the speakers had nothing more then a wire coming out of them (if you know what I mean)
-----SURROUND SPEAKERS-----
RCA (red and white)
Thats about it, if this helped in anyway. Ill try cleaning the leads to see if anything changs.
