Latest post 06-14-2009 5:13 PM by Razlaw. 11 replies.
Page 1 of 1 (12 items)
  • 06-12-2008 9:58 PM
    BV7BS3 speaker connections
    In anticipation of purchasing a BV7 I was reading the guide for it on the B and O web page. I noticed that speaker connections are labeled 1-6 rather than front and rear as on our current Avant. When we built our house B and O installed in wall wiring for the rear speakers in the surround setup. I run one powerlink to a connection in the wall behind the Avant. The in wall wiring then runs in series to to powerlink connections located where each of the rear speakers are. I then set one speaker to left and one to right.
    It appears in the BV7 guide that each speaker out connection, 1-6 must be assigned to a specific speaker. If true that seems to mean the rear speakers can not we wired in series and I will not be able to use the in wall wiring for one of the speakers and will have to run a seperate new powerlink wire to that location?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 06-12-2008 10:13 PM In reply to
    Re: BV7BS3 speaker connections
    As confusing as it may sound, the BeoSystem 3 will recognized daisy-chained speakers without issue. You will find that when assigning speaker types in the menu it will "fire up" each speaker individually and allow them to be named and configured individually, even if they're running out of the same socket.
    Nothing at all to worry about!
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 06-12-2008 10:39 PM In reply to
    Thanks once again!  Now if  my wife and I could just get over the little part of us that wants a BV4 and then actually get the BV 7 ordered. LOL
  • 06-12-2008 11:57 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Honestly, unless there is an issue with screen size, no one wants a BV-4 more than a BV-7.  If you love your Avant, you will love its 'Grandson'.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 06-13-2008 12:14 AM In reply to
    I am glad to hear you say that.  We feal the same way about the 7. Everybody is so preoccupied with screen size however we find ourselves succumbing to the temptation to look just at screen size. We sit 10-13 feet from the screen so either would work, 7 maybe just a little small, 4  just a little too big...but certainly a matter of taste.
  • 06-13-2008 9:56 AM In reply to
    • kawo
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 516
    RussR:
    I have to say that I have chossen a BV4 over a BV7....because I have a screen comming down for my projector and it will be at least a challenge to operate the DVD tray :-)  However, I have an older model with nice alu frame and not the new one....grrrr...don't like that one!
    So size is not the only reason....
    Karsten
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
  • 06-13-2008 8:43 PM In reply to
    Is your preference for the BV7 based on the overall design of the TV, ie it looks like something special from B and O rather than just another plasma on the wall, or is it the picture quality? or both?
  • 06-13-2008 9:31 PM In reply to
    • Russ
    • Posts 641
    It is indeed both Razlaw,
    The BV-4's have an unquestionably amazing picture, and I generally tend to prefer Plasma to LCD in general.  But beyond a certain point, even the BV-4 is simply a frame hanging on a wall.  The BeoVision 7, for me, so perfectly captures some of the 'mojo' about which there is another thread here, that it is without question the morer attractive, satisfying product overall.  And its picture is stunning!
    Russ
    McLean, VA USA
  • 06-10-2009 5:01 PM In reply to
    TripEnglish:
    The most that can be daisy chained are two different speaker roles? Correct? Such as left surround and right surround?
    It is not possible to, for instance, daisy chain 3 such as left surround, rear centre, and right surround?
  • 06-11-2009 2:47 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Razlaw:
    No, center and sub speakers cannot be daisy'ed, so daisy only works in pairs of 2 speakers with "the same role, but left and right". The powerlinkcable only contains left/right signal cables.
    /Weebyx
  • 06-11-2009 7:30 PM In reply to
    Thanks!   That's what I thought.
  • 06-14-2009 5:13 PM In reply to
    I just tried something.  I added an additional speaker to the BV7 menu (even though one was not actually connected) I assigned it the role of Right Surround. After doing this I was able to assign the two speakers that are connected, in series, as Left Surround and Rear Centre. So it does appear that in some instances speakers can be connected in series other than just right and left.
