Latest post 06-12-2008 5:11 PM by Beoik. 2 replies.
Page 1 of 1 (3 items)
  • 06-12-2008 11:27 AM
    • beowhit
    • Not Ranked
    • Joined on 04-17-2007
    • Brompton, Kent
    • Posts 26
    Beovision 4
    Hi all,
    I've been offered a second hand Beovision 4 42" non HD and Beosystem 2 for not a lot of money. I've not seen it as yet, but believe it's in very good condition and lightly used.
    Whats people's opinions on this TV? - picture quality, reliability etc. Any known problems?
    Many thanks
    Mark
  • 06-12-2008 3:06 PM In reply to
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    Re: Beovision 4
    Very good quality and reliability. Depending on the age of the panel it MAY be able to upgrade to HD, via a software update in the Beosystem 2 and a firmware upgrade and blade in the Beovision 4. I'd check with a dealer to see if the serial number denotes it as a D6 or D7 panel - if it is D& then you are laughing.
    Either way, if you are only looking at SD material, then it is a fine unit.
  • 06-12-2008 5:11 PM In reply to
    Re: Beovision 4
    is every d6 panel upgradeable?
