Steve,
The Beomaster 1001 (and 1200) uses the bottom chassis plate as a heatsink.
If it gets warm within 5-10 minutes you need to get the amplifiers idle current checked, in this case the heat buildup will be more or less
concentrated around a pair of the transistors mounted underneath, at least to begin with.
Normally, after one hour of playing with good listening volume, the whole bottom plate will be "pleasantly" warm ie. not more than handwarm and not particularly concentrated. If it gets "very hot" as you describe, you should have it checked. Should be a cheap repair in that the symptoms are well-known, the components are cheap and fairly easy to reach.
