Latest post 06-14-2008 4:42 AM by villarsch. 6 replies.
Page 1 of 1 (7 items)
  • 06-11-2008 9:57 AM
    • villarsch
    • Not Ranked
    • Joined on 04-21-2007
    • Frinton-on-Sea, Great Britain
    • Posts 37
    TV LX2500 and Freeview box
    Although this TV is over 20 years old my wife insists on keeping it because of the rosewood surroundI  So, in order to get the best possible use from the set, I am going to link it to a Freeview box.  As there are so many of these on the market, I would appreciate any advice or recomendation on which make of Freeview box to buy, either as a simple box, or perhaps a box which incorporates both a hard drive and a DVD recorder. Many thanks, and my apologises if this question has been raised previously.
    villarsch
  • 06-11-2008 10:08 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: TV LX2500 and Freeview box
    Hello
    The BeoVisionLX2500 television is to old to accept a Set Top Box controller to enable operation of the Freeview box via your B&O remote control. Consequently the choice of box is not limited to one that the B&O software supports.
    I have had very good reports of the Topfield PVR5800. This is a twin tuner Freeview box with integrated Hard Drive.  I believe that there are two versions available depending on how much capacity you think you will need for recording programmes.
    Opman
  • 06-11-2008 10:48 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    We have had a Sagem Freeview box for over 2 1/2 years now. It does not have a hard drive, but if you want just a Freeview box Sagem are very good IMO. We use it with an MX5500 and the picture is superb.
    CraigSmile
  • 06-11-2008 12:41 PM In reply to
    Villarsch,
    The Topfield PVR5810 is very good and easy to use with large disk (500GB) option, like almost all of these types of STB's there are a few niggles.
    Regards Keith....
  • 06-11-2008 1:28 PM In reply to
    What about a Thomson DTR-6300? Great little twin tuner,hddr (250g)Very nice handset and logical operation.Comes with Top UP Tv option included.Good price too!
  • 06-12-2008 9:17 AM In reply to
    I have a Topfield 5800 with 160GB ... which in my opinion is plenty ... more than this is wasted money, unless of course you want to keep 6 months worth of every soap that the BBC and ITV put out.
    Niggles are almost none and the user interface is streets ahead of anything else I have used.
    Neil
  • 06-14-2008 4:42 AM In reply to
    • villarsch
    • Not Ranked
    • Posts 37
    Thank you all for your helpful advice.  It has been decided (decreed) that there will only be a FreeView box, no recorder.  So I am getting a Humax F2-Fox-T which, it is claimed, has a high sensitivity.
    Finally, a thank you to Beoworld, as I have made use of their library and have down-loaded the LX2500 handbook
    Villarsch
