Latest post 06-11-2008 4:33 AM by 9 LEE. 4 replies.
Page 1 of 1 (5 items)
  • 06-10-2008 6:45 PM
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Which SP is this?
    Hi All
    Have had an email from a gentleman who would like to know which vintage B&O cartridge this is...  I am sure someone will know, and i will point him in the direction of this thread to hopefully find the answer!
    Lee  Smile
  • 06-10-2008 6:46 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Re: Which SP is this?
    and another shot.... Hmm
  • 06-10-2008 7:12 PM In reply to
    It looks like either the SP6 or SP8 that was for non-Beogram decks; they're in the 1967 catalogue. Also looks like the pins have been bent to fit inside the cartridge shell more tidily.
    Cheers, Steve
  • 06-11-2008 2:12 AM In reply to
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    This is the SP1 / SP2 pickup type
    This is an 30dg. design for the early stereo cuttings at a time where the angel was not standard. Actually - it was B&O Mr. Rørbæk Madsen who propssed the first standard to be the later 15dg. which all later SP pickups were designed for (SP6/7 ----> )
    This particular version is for a non B&O tonearm.
    Of coarse B&O used the SP1/2 and the tonearm was also designed for the 30dg.- http://www.beoworld.org/prod_details.asp?pid=911
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
    Filed under:
  • 06-11-2008 4:33 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    http://www.beoworld.org/prod_details.asp?pid=710
    BeoWorld Product Page updated!
    Yes -  thumbs up
    Thank you Frede Smile
