I'm confused as to how to select the iTunes playlist to use with the Timer with BM-Link. The instructions on Anders' website are:
"For N.MUSIC the program option means which playlist to start playling. The Library playlist is number 1. For N.RADIO the program options means which channel in the N.RADIO playlist to play."
Where does one access the option to select "program"? I can't find this anywhere in the BM-Link control panel under system preferences. I also can't find this on the menu of my BeoCenter 2. Do I need a software update to my BeoCenter 2 to select the "program" for N.Music on the Timer?
