Latest post 06-10-2008 3:47 PM by Bv7Mk3. 4 replies.
Page 1 of 1 (5 items)
  • 06-06-2008 10:04 AM
    Help!
     Hi all.
             I have a Bv 7-40 mk3 tv in which I have a real problem which has been bugging me.The Internal Dvd Player will not output any picture to my Projector when in cinema mode BUT is ok with Dtv,Norm Tv,Sky Hd & Playstation 3.The Sky & Ps3 Is through the Hdmi Ports and switching back and forth between everything ok but not the Dvd.
    I Have had a new Dvd Player fitted as the the last one failed and stopped playing any dvd's.This did not sort out the Dvd sending  to projector problem!
    I really don't want to lose the Bv 7-40 fab picture but I have tryed Two Beosystem 3's which work fine and have been offerd a swop over/refund the only thing is at this moment in time im unable to afford a bv4 just yet.
    What Normal screen would work with the Bs 3 for around £1,400.
    A Glass Fronted screen,like the 7-40mk3 has,would be nice.
    Thanks.
    Roj.
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
  • 06-06-2008 10:47 AM In reply to
    Re: Help!
    The best non B&O screens to use with a BS3 would be the panasonic
    TH50PF10 - 50" Full HD Plasma. Approx £2000
    TH50PH10 - 50" HD Plasma. Approx £1350
    TH42PH10 - 42" HD Plasma. Approx £750
    All these can be controlled in a similar fashion as the BV4 together with a RS232 cable + DVI -> DVI/HDMI cable.
    The above panels are the same panels, which B&O uses inside the BV4s.
    Christian
  • 06-06-2008 6:14 PM In reply to
    Re: Help!
    Thank you for your reply and do you know if there is anything that can be done about the in built dvd player not outputting to the projector? As I would like to keep the tv if possable.
    What equipment are you useing with your bs3?
    roj.
  • 06-08-2008 9:18 AM In reply to
    Re: Help!
    I unfortunately don't know enough about the BV7 to help you with your DVD problem.
    I have just ordered the TH50PF10 for my BS3 - so haven't received it yet, but I will get it next week.... Party!!!
  • 06-10-2008 3:47 PM In reply to
    Re: Help!
     Hi and Thanks and I bet you can't wait for the Panel for your Bs3. It would be great to tell  me what you think of it when its up and running.
    As for my dvd problem,Im wating to see what b+o says/can  do (as I called them today)otherwise my dealer will take the tv back from meBig Smile Who has been very helpfull with this problem!.
