1st March February 2012
Latest post 06-07-2008 2:30 AM by Ignace. 13 replies.
Roger
- Joined on 03-28-2007
- Norway
- Posts 870
Re: The new STB-C table 4.01
The complete lists for each chip are now available here on BeoWorld (the gold membership is required to access them). Roger
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Erik, how do you fast scroll with the apple remote using frontrow in i-tunes? If this would work with the Beo 4 ... perfect! Thanks. Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
cowtwn
- Joined on 10-01-2007
- Posts 14
where abouts is this information- i could not find it
Ignace
- Joined on 03-30-2007
- Moderator - NL
- Posts 2,749
Products / User & Service Manuals / Televisions / Sat Receivers & Accessories / STB-C
kawo
- Joined on 04-17-2007
- Posts 516
hmmm...can't read I just see black bars in the document! Karsten
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
Ignace
- Moderator - NL
- Posts 2,749
I checked the files (pdf), they open normally on my pc. Do the other pdf-files have the same problem ?
hebo
- Joined on 04-16-2007
- Sweden
- Posts 305
can´t see them with my mac, just bars..... just like karsten
stefan
- 200 miles from Struer
- Posts 1,733
Same problem here - just black bars on my macbook... Stefan
kallasr
- Posts 1,077
No problem here, PC, Adobe Acrobat Reader 7.1.0. Maybe you need to update the Reader? Ralf
Ignace
- Moderator - NL
- Posts 2,749
I remember having difficulties uploading the files. Could you try to download this file : West Europe May 2008 TEST and see if it opens normally ? Thanks, Ignace
kawo
- Posts 516
The Test file works on my iMac! No black bars. Karsten
Ignace
- Moderator - NL
- Posts 2,749
Thanks Karsten. I will create new pdf-files of the STB-lists.
Ignace
- Moderator - NL
- Posts 2,749
New pdf-files have been created and uploaded. Should there still be a problem with opening the files, please let me know. Ignace
Page 1 of 1 (14 items)
