You need to exchange the front piece of the piece of the speaker to be able to attach the Alu Frets.
That does sound difficult & expensive but in fact its not. I did it for mine and was worth the effort.
Took 10 minutes to do, you need to be quick and some point I think I heard they stopped selling spares for the BL2500 and the fornts were considered that. Baffle Kit is called what you need.
Cheers
JK
