Latest post 06-06-2008 1:10 PM by solderon29. 3 replies.
Page 1 of 1 (4 items)
  • 06-04-2008 2:18 PM
    Beovision MX 4500 help required
    Hi all.
    For many years now I have lovingly owned a Beovision MX 4500. I puchased it way back in the 80's in Hertfordshire, England and it moved with me to Northamptonshire and now (having just moved again) over to North Carolina in the USA. It still looks great and works great Big Smile
    Unfortunately over the years I have mislaid the owners manual (it is probably in one of the many moving boxes still waiting to be unpacked).
    What I desperately need to know is how to change the channel frequency reception to NTSC.  I have tried many combinations from the remote but all to no avail. The remote is not the original - it was replaced with a similar later model B&O remote when the keypad needed replacing and the old style keypad layout was no longer available.
    Some help on this would really be appreciated.
  • 06-05-2008 3:20 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Beovision MX 4500 help required
    Hi NightOwl,
    Welcome to BeoWorld Smile
    To switch between the tv-systems, press SHIFT + 3.
    "B" = PAL/SECAM B/G
  • 06-05-2008 5:52 PM In reply to
    Many thanks for the reply Ignace.
    The SHIFT + 3 certainly changes the setting form B to L or M Smile ....(though I'm not 100% sure which off L or M is NTSC.
    I have the satellite service Direcxtv installled and they installed 3 receivers in different rooms. 2 work fine  (on my new Phillips HD tv and also a computer with Windows Media Center). The 3rd receiver was for my MX 4500.
    Having changed the setting to L and done a frequency scan I find that I can get a black and white picture of the tv guide when the satellite receiver is in tv guide mode but as soon as tv guide mode is exited the picture disappears completely....... very strange.Hmm
    To ensure that the TV powers up and runs ok I purchased an up-converter that converts USA power up to 220 volts so it is not a power issue. For some reason it is just not recognising / able to display the American picture or sound transmission.
    My wife and I will be totally gutted if we don't get it working as we both love that tv.
  • 06-06-2008 1:10 PM In reply to
    If your MX4500 is capable of processing NTSC signals,you will have an M option after pressing tv-shift-3.eg:B= Pal/secam BG/I.L= Secam L,and M=Ntsc.
    The original spec allowed for NTSC,but only if some alterations were made.Later sets did incorporate this feature,but if you don't have the M option,I suspect your set will not cope!
    Ntsc to Pal converters are available quite cheaply here in the UK,you could connect one of these between your cable box and the MX4500 scart socket,and problem solved!
    Regards,
    Nick
