Where can I get a replacement stylus for a BEOGRAM 2000, other than B&O or ebay ? Any suggestions would be great, and advice on the types that are compatible, Cheers
http://www.sound-smith.com/
http://www.schallplattennadeln.de/
These were mentioned before for good prices/service.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Compatability of cartridge depends on which model Beogram 2000 you have.
The 1970's BG2000 will accept the SP range (except the SP15 which has a totally different fitting and you probably won't find in any case). The stylus can be replaced on these cartridges.
The later 1980's BG2000 will accept any of the MMC1 to MMC5 range of cartridges only and have to be changed as a complete unit as they are integrated. Soundsmith's SMMC4 would be my advice in this case.
Chris.
Thanks a million for the advice its the older 5240 model
Beomatt: Thanks a million for the advice its the older 5240 model
In that case you want to go for an SP12 as this is the best of the range.
