Latest post 06-04-2008 8:29 AM by nobby. 3 replies.
Page 1 of 1 (4 items)
  • 06-02-2008 11:40 AM
    • maqfet
    • Not Ranked
    • Joined on 06-02-2008
    • Posts 2
    MX6000 with a sound fault
    Hi Guys, I've only just joined today and have read many of the comments.
    I am looking for info regarding this fault.
    The set works fine, within 10-15 minutes of switch on, the sound begins to distort and stays that way. I've replaced a couple of electrlytics in the audio amp cct but don't have much experience with this fault. Any ideas or guidance please?
    Filed under:
  • 06-02-2008 12:53 PM In reply to
    Re: MX6000 with a sound fault
    Is it only on tuner or with both SCARTs too?
  • 06-04-2008 4:39 AM In reply to
    • maqfet
    • Not Ranked
    • Posts 2
    Hello there, it's on all sources and that's why I went to the audio amp circuit. I noticed that you are the author of much feedback with the MX5500, do you think this fault may be due to capacitors in the power supply??
  • 06-04-2008 8:29 AM In reply to
    Have you checked the quality of the solder joints on the audio amp chips?  They are 9 pin devices mounted on the heatsink.
    Neil
