Hi Mika,
Looks like we're on the same "wavelength" here! Isn't it a bit early yet for summer in Finland?
You're absolutely correct - it is the sliderule / carriage sensor.
Like yours, that was a similar problem with mine - the arm would not recognize the 45 position. I did try the normal repair, which is to adjust the incandescent light to a straighter angle, but there was no improvement.
So, I assumed that there is a problem with light quantity. I replaced the weak incandescent light with a bright white LED. It was a very simple mod, with the addition of one resistor only. See picture.
So, the problem of the 45 position was fixed.
Now, once in a while, when I press START, the arm goes to the edge of the LP, but instead of lowering to the LP, it reverses direction, and returns to rest. This is the only problem remaining.
(I can get around the problem by pressing START, then immediately <, then, when the tonearm is over the LP, press V )
OK, so I've looked at the specs of the TPS622 - looks like I can pull one out of a broken Opti-mouse.
But the datasheet says that it will work optimally with an infra-red LED (probably for a peak sensitivity wavelength of about 800-900nm. I have a bright white LED installed - White light is operative at all wavelengths. What's your opinion?
If we use an LED light and TPS622 type sensor, would we still need to mod the amplifier stage?
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
