Latest post 06-01-2008 1:31 PM by Kirky. 4 replies.
Page 1 of 1 (5 items)
  • 06-01-2008 12:30 PM
    • Kirky
    • Not Ranked
    • Joined on 06-01-2008
    • Posts 3
    Help - No remote connection on Beosystem 2500
    Can anyone help. I've had my Beosystem 2500 connected to my BV3 via a Beolink converter. It served me well until I found enough courage to spend the money on a BS9000 and set of BL9's. I have now connected these to the BV3 and am very happy with the system. I have moved the 2500 upstairs to my bedroom but the Beo4 does not talk to it anymore. I think this is a function of the BV3 having controlled it. The unit works perfectly; just no talking between it and the Beo4. Can anyone suggest a way to make it communicate?
    Kirky
  • 06-01-2008 12:59 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Help - No remote connection on Beosystem 2500
    Press Standby + List at the same time on your Beo4. Select A.Opt with the up + down arrows and press GO. Press 1.
    And welcome to BeoWorld. Smile
     Weekly top artists:
  • 06-01-2008 1:03 PM In reply to
    You have the option set to 0 and it should now be 1 to make the remote work.
    With the 2500 in standby
    With your Beo4, press STBY and LIST together
    Now LIST until display says OPTION ? and press GO
    Now LIST until display reads AOPT and press 1 and GO
    Red light on 2500 should blink and remote will now work!
    Regards Graham
  • 06-01-2008 1:29 PM In reply to
    • Alex
    • Posts 2,990
    I always end up missing that step out...
     Weekly top artists:
  • 06-01-2008 1:31 PM In reply to
    • Kirky
    • Not Ranked
    • Posts 3
    Alex and Graham,
    Thank you. All is well in the household. So simple when you know how!
    Regards
     Kirky
