I used to have a watch like that!!
Joking apart, it could be a stretched belt or, as you suggest hardened lubrication. I think the former, as it taks a while for it to get going.
Don't like the sound of forcing anything, I'd hate you to break something.
To lift the platter off, just push down at the front, and the back will lift enough to get hold of ot, the belt will be visible then.
Andy T.
