Latest post 05-31-2008 2:21 PM by burantek. 6 replies.
Page 1 of 1 (7 items)
  • 05-31-2008 1:39 PM
    Beosound 9000 "TV Contol" Message
    When trying to adjust the volume the display reads "TV Control" and the volume stays the same. I don't have a user manual. How do I adjust this?
  • 05-31-2008 2:06 PM In reply to
    Re: Beosound 9000 "TV Contol" Message
    You probably have the wrong option set. It assumes there is a TV which has the speaker connected.
    Try switching it into option 1
    http://www.beoworld.org/beotech/mlsetups.htm
    Link above is how ..
  • 05-31-2008 2:07 PM In reply to
    this sounds like you are connected to a tv... is that the case?
    if it is some of the bs9000 features are controlled from the set.
    • B&o bottle opener
  • 05-31-2008 2:11 PM In reply to
    The 9000 is not hooked up to a TV. It is possible it may have been in the past.
  • 05-31-2008 2:12 PM In reply to
    then follow jk's advice above my post... there is an option set incorrectly...
    i will look into it in the meantime...
    someone here will get you straight.
    • B&o bottle opener
  • 05-31-2008 2:16 PM In reply to
    My installer just figured out the option menu on the remote and fixed the problem.
    Thanks for your responses.
  • 05-31-2008 2:21 PM In reply to
    very good!
    that was my next q: do you have a remote? [;-)]
    well, glad you got it sorted!
    and welcome to beoworld if you wish to stick around!
    • B&o bottle opener
