Hi Peter,
Thanks for the reply.
Yes I think there is something wrong with it.
Everything sounds slightly slower than on CD.
I downloaded the manual and couldn't find
anything to suggest I could adjust this myself?
Regarding a preamplifier, the only one I could find
that looks suitable is this one.
http://www.maplin.co.uk/Module.aspx?ModuleNo=28732&TabID=1&C=SO&U=strat15&doy=search
Is this suitable and any suggestion for something a
bit higher spec if this one isn't that good?
Thanks again.
