Hi Yann, you are right, this function does not exist in the config tool, but the command is in my Beo5 setup for the PandP function.
You can type the words into the command field and create this way a new command.
Sorry, as I said before, I can not test the button, because I don`t have the BV with PinP.
Good luck
Stefan
