Latest post 05-30-2008 12:45 PM by Dave0280. 4 replies.
Page 1 of 1 (5 items)
  • 05-28-2008 4:45 PM
    • Dave0280
    • Top 500 Contributor
    • Joined on 03-05-2008
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Beocenter 9000 woes...
    My 9000 isn't giing me the best time of late - recently a speakerlink socket at the back has been playing up. Occasionally it will work fine and then other times the speaker will be crackly or not working. Its definitely the socket at the rear of the 9000 - a common problem or any easy DIY fix? Or - now that the CD spring has packed up - is it time for the 9000 to go in a spares or repair ad on Ebay!! Really dont want to get rid of it to be honest!! May just leave it on the shelf to look pretty!!
    Dave - Birmingham, UK
  • 05-28-2008 6:35 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beocenter 9000 woes...
    No no no Dave!
    Don't get rid, it's probably an easy fix, may be just a dry solder joint.
    Poor me, never win owt!
  • 05-29-2008 2:43 AM In reply to
    If it's plugged into a Spk1 socket then your problem is probably the "Mute" relay which needs replacing.
    Regards Graham
  • 05-29-2008 4:55 AM In reply to
    Have you tried repeatedly switching the mute relay on and off lots of times? Worked on my BM 5000 when I had a similar problem.
  • 05-30-2008 12:45 PM In reply to
    • Dave0280
    • Birmingham, UK
    • Posts 126
    • Gold Member
    Thanks John and chaps - will give it a go and hopefully breathe some more life into the old girl.
