Latest post 06-15-2008 6:44 PM by Piaf. 4 replies.
Page 1 of 1 (5 items)
  • 05-26-2008 11:12 PM
    • Piaf
    • Top 150 Contributor
    • Joined on 07-08-2007
    • Victoria, British Columbia
    • Posts 409
    Third NEW issue with Beogram 4002
    New issue with a Beogram 4002.
    First the tonearm was moving back and forth (side to side) too much and this was adjusted.
    Following this, the tonearm once in play caught up with the senor arm. Yet another small adjustment, and all was fine.
    Now a new issue. The tone arm drops but “lands” too far into play. The 4002 plays all right, but if fast-forward is selected and the “down” control is pressed, the arm does not drop only moves quickly to the left. No amount of coaching can get the arm to drop other than in the beginning of play.
    So now what do I do?
    Jeff
  • 05-28-2008 1:00 AM In reply to
    • Piaf
    • Posts 409
    Re: Third NEW issue with Beogram 4002
    Martin, Peter, any ideas with this new problem? [:'(]
    I am down to one working Beogram out of four.... HELP! Sad
    Jeff
  • 05-31-2008 2:27 AM In reply to
    • Piaf
    • Posts 409
    Come on guys, have you forgotten me? This is serious and I really need help. [:'(]
    Jeff
  • 06-02-2008 4:00 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Hi Jeff,
    My BG6000 is also an ex-Canadian unit, which apparently had many unauthorized fingers fiddle with it over the years. Slowly, I've been taking care of all the previous sloppy workmanship, as problems came to light.
    My latest problem has similar symptoms to yours, which I've traced down to the PhotoResistor circuit.
    See this post:
    http://forum.beoworld.org/forums/thread/120432.aspx
    Regards
    Menahem Yachad
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 06-15-2008 6:44 PM In reply to
    • Piaf
    • Posts 409
    Hi Martin,
    The problem of the tonearm being dragged across the record has been located, if not permanently fixed.
    The issue is at the senor which “thought” the tonearm was too far to the right, hence the leftward drift. Once adjusted the up/down function is back and the 4002 is again playing records.
    Unfortunately, after a single play the tonearm appears to be pushing too hard (or too fast) to the left and first bends the stylus to the right until the stylus is dragged over several grooves. This tonearm adjustment certainly gets out of adjustment FAST!
    At least we know it is not a serious problem, but I don’t know that I want to try another adjustment today.
    Thanks for all your help!
    Jeff
