Latest post 05-27-2008 2:49 AM by 850volan. 2 replies.
Page 1 of 1 (3 items)
  • 05-26-2008 4:27 AM
    Beocom 2000
    Hi All!
        I happened to get a Beocom 2000 corded phone but this one is a bit different from mine in that on the front at the lower left corner ,there is a headphone icon button instead of speaker(handsfree) icon and at the back ,there is an extra handset socket (i believe it's for headset cos there is no other socket for headphone)  Just wonder how i can connect a regular headset to this socket? Any kind of adapter available? or anyone have the same phone and using headset ?
        Thank you.
    Filed under:
  • 05-26-2008 8:06 AM In reply to
    Re: Beocom 2000
    I am aware that there was two versions of the Beocom 2000 one with headphone socket and one without.
    Check the 4 digit Type number for each phone, as I think you will find that one will have only ever been sold in Denmark, Sweden or Holland.
    Regards Keith....
  • 05-27-2008 2:49 AM In reply to
    Re: Beocom 2000
    Hi Keith !
       You got it right again! I got it from Copenhagen. Just wonder if this one can be used handsfree(without headphone) or it must only be used with headphones. Anyway i tried it and it seems like i have only one option, headphones. If i have to use headphones ,how will i connect it or is there any kind of adaptor for this?
        If i have to make my own adaptor,is it possible that i use it to connect to my Beocom headset for mobile phone with 2.5 mm jack?  It would be great if i can integrate these together. Any idea?
       Thanks for the reply,and Viva Beoworld!
