Latest post 05-26-2008 6:29 AM by BenSA. 6 replies.
Page 1 of 1 (7 items)
  • 05-25-2008 10:26 AM
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Beocenter 2500/Beosystem 2500???
    What essentially is the difference between the two? Is one with speakers and one without?
    Is it possible to connect passive speakers to the 2500 in any way??
    Durban South Africa
  • 05-25-2008 11:17 AM In reply to
    Re: Beocenter 2500/Beosystem 2500???
    The two systems are very similar, but the Beosystem 2500 has Beolab 2500 speakers and also Masterlink.
    The Beosystem connections are:-
    FM aerial, 75 ohm 1
    AM aerial (Dedicated) 1
    Beocord Tape 2 Via Aux socket
    Beogram LP (RIAA built-in) Via Aux socket
    Beolab speakers 2 x Power Link
    Beovision Via AUX socket
    Local rooms, speakers 2 Via MCL 2P
    Aux 7-pin socket
    Masterlink
    Regards Keith....
  • 05-25-2008 1:18 PM In reply to
    Keith Saunders:
    FM aerial, 75 ohm 1
    Aux 7-pin socket
    Masterlink
    There is no difference. The beosystem is simply the beocenter with beolab 2500 speakers.
    There is no masterlink in either product. The first masterlink product of this type was the Ouverture.
    Regards Graham
  • 05-25-2008 7:30 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    francoisvl:
    Yes but you need a Beolink passive to do this. Usually quite expensive but have been known to go for a fair price on ebay if you find a badly listed one.
    Chris.
  • 05-26-2008 2:51 AM In reply to
    You are right Graham, not sure why I thought that the Beosystem 2500 had Masterlink....Beer
    joeyboygolf:
    Keith Saunders:
    FM aerial, 75 ohm 1
    Aux 7-pin socket
    Masterlink
    Regards Keith....
  • 05-26-2008 5:23 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Medogsfat:
    francoisvl:
    Chris.
    The brochure of Beosystem 2300 / 2500 also mentions the MCL2P for connecting other speakers.
    (ML/MCL-converter, used as MCL2P)
  • 05-26-2008 6:29 AM In reply to
    • BenSA
    • Posts 808
    • Gold Member
    Was in the market for one but then the deal fell through but the information that you have posted is still valuable incase another one pops up!!
    Thanks!!
    Durban South Africa
