Latest post 05-26-2008 1:31 AM by yachadm. 5 replies.
Page 1 of 1 (6 items)
  • 05-24-2008 7:39 AM
    • Gregor
    • Not Ranked
    • Joined on 05-24-2008
    • Posts 3
    beomaster 2000 tuner string replacement
    Hi, I have just bought a beomaster 2000 as much for the look as anything, but I think I will use it and downgrade the NAD 3020.
     Only one problem is that the tuning string had come off the small guide wheels. I was unable to get enough stretch to fit it, and then it snapped.
    Can anyone recomend a method for replacement (I have a length of new tuner string)?
    Thanks, Gregor
    Filed under:
  • 05-24-2008 11:37 AM In reply to
    Re: beomaster 2000 tuner string replacement
    Which 2000? There are two. Is yours the one with touch sensitive keys ( good looking amp) or the earlier one with the huge tuning dial (superb sounding amplifier).
  • 05-24-2008 9:34 PM In reply to
    • Gregor
    • Not Ranked
    • Posts 3
    Hello Peter,
    mine is the  type 2801, with the large tuning dial.
     Yeah, the amp does sound superb - as I said, I better than the NAD.
    Another question: is the quality of the 5 seperate FM preset tuners as good as the larger tuning device that is operated through the dial.
    Thank you for being available to assist. It is much appreciated
    Gregor
  • 05-25-2008 3:26 AM In reply to
    The full service manual is on site should you need it though you need to be at least a silver member. I attach the diagram for the tuning cord though. The presets are fine though setting them takes a little patience. The system was very similar to almost all Beomasters of this era with only the Beomaster 2200 having a better method.
  • 05-25-2008 4:39 AM In reply to
    Gregor:
    Sound/tuningwise no difference - they are just trimpots, and the dial operated device is another potentiometer (AM ranges have a variable cap). However, mechanically they may have problems. I bought two of these machines, and together they had one (1) preset that worked when they arrived to me. They get stuck. If they are heavy to turn or the indicator doesn't move at all, desolder them, carefully pull off the thumbwheel, spray some cleaner/lubricant on the axle and work it with pliers until it moves well. I got them all fixed this way.
    I also have a lot of experience with the dial cord Laughing Lacking "official" cord, I had to go through something like three different types of line until I found one that works. First thread it on the pulley of the varicap (turn it fully to one side first, attach the spring and think which way you have to thread), then the dial pulley and the two small pulleys on the left, this way you don't have to stretch it too much when you pull the cord on the last pulley at upper right. Leave the dial pointer last. I actually made the cord loop a little longer and put one additional turn on the dial pulley so it wouldn't slip so easily (if you have a correct type of cord, this shouldn't be necessary).
    One more thing, the guide/spring of the wires going to the dial pointer has to be attached right (there's a hole in the holder at the other end where you have to stick it), otherwise it won't stay flat on the dial once you assemble the unit, and will get caught in the components below. I spent many a frustrating moment with this... Also remember to lubricate the guide rail for the dial pointer, which likes to get stuck as well.
    While you have the dial apart, clean the dial window rails and reglue them, they are probably cloudy and loose anyway. Don't break the dial pointer light bulb, it's a pain to replace.
    Good luck and have fun with this excellent receiver!
    -mika
  • 05-26-2008 1:31 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Hi Gregor
    I have the Beomaster 3400, which has the same chassis as your Beomaster 2000.
    I'm not sure if it has the same dial-cord arrangement, but here is a picture of my unit - perhaps it can help.
    Also, I have since restrung the cord with fishing-line. Very strong and durable.
    Regards
    M Yachad
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
