Latest post 05-29-2008 7:49 AM by mor. 11 replies.
Page 1 of 1 (12 items)
  • 05-24-2008 5:08 AM
    BeoVox/BeoLab 5000 Active Loudspeakers
    hi
    doas somebody know the compatibility with BeoLab 5000 Active Loudspeakers to some new B&O product(beosound 2300,2500,3000,3200,or beosound 4or some beosistem) and if the display showing which source was playing and at what volume?
    BeoLab speakers were designed to match Beosystem 6500, 4500, 3500 and Beocenter 9500 and 8500.
    THX
  • 05-24-2008 5:17 AM In reply to
    Re: BeoVox/BeoLab 5000 Active Loudspeakers
    Beolab 5000s will work with all modern systems moreso any system which has powerlink.
    I use mine in a link setup via a BS9000 if that helps and still has use of its display etc.
    Sound awesome!
  • 05-24-2008 6:42 AM In reply to
    They will work perfectly - you do need fully wired Powerlink cables though.
  • 05-24-2008 8:20 AM In reply to
    but what about the dispay
    doas it show the surce and the volume if is conected with beosound 2300,2500,3000 or beosound 4
  • 05-24-2008 8:59 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Sad [:(] Re: BeoVox/BeoLab 5000 Active Loudspeakers
    Yes, display shows that information with all above mentioned Beocenters / Beosounds.
    Peter already mentioned that you will need the fully wired Powerlink-cables.
  • 05-24-2008 1:22 PM In reply to
    • mor
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Cologne
    • Posts 104
    I had mine connected to my BeoVision 5 for some time - sound great and displays are fully functional! So even if you route them through the TV to do surround - they are a great choice!
  • 05-25-2008 4:42 PM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    N.MUSIC will show as "A.TP 2", and N.RADIO as "PHONO", but that is only relevant if you use a BeoPort.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 05-26-2008 12:02 AM In reply to
    • dylan
    • Perth, Australia
    • Posts 117
    But if connected directly to Beoport you won't get any display - my 4500s display fine connected to the BS3200 but nothing when connected to beoport - which is where I use them Sad.
    BS3200 BV7 BV3 BL8000 BG4000 BL4500 PC2 BG5500 MX4002
  • 05-27-2008 8:46 AM In reply to
    my local dealer inform me that beolab 5000 dispay dont show nothig when is conected with on beosound 4 ???
    did somebody try this configuration???
  • 05-27-2008 9:08 AM In reply to
    lomamalo:
    that's wierd, I've got a Beosound4 with 1 pair of BL5000 and 3 pairs of BL4500 connected to it and all displays are working fine............Hmm
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
  • 05-27-2008 9:28 AM In reply to
    beologisch:
    lomamalo:
    And I recently had BS4 in sales stock and connected to my BL5000's the displays worked fine!
    Regards Graham
  • 05-29-2008 7:49 AM In reply to
    • mor
    • Cologne
    • Posts 104
    Sounds to me more like the wrong (not fully wired) wires ...
