Latest post 01-13-2010 5:50 PM by MoglesMac. 4 replies.
Page 1 of 1 (5 items)
  • 05-23-2008 11:50 AM
    Beogram 1202 - Automatic arm question
    Hello Folks,
    My first post here so be gentle with me!
    I recently bought a faulty Beogram 1202 (very cheaply) with the intention of fixing it up. I've solved most of it's issues - including making a new belt for it from some 3mm Nitrile Rubber O-Ring Cord! It's now running very well and sounding great.
    My only problem is that the tone arm doesn't quite hit the starter groove when I press the Lift button to start the play sequence. Also (part of the same problem I'd guess) the arm returns a little early at the end of a record.
    I would imagine it's a simple tweak here or there to make the adjustment, but I thought I would consult the experts here before I do it by trail and error!
    Thanks in advance.
    Hopefully as my B&O collection (mostly vintage) grows I shall frequent these shores more often.
    Luke.
    Filed under:
  • 05-23-2008 2:47 PM In reply to
    Re: Beogram 1202 - Automatic arm question
    The full service manual is on site though you will need to joinh as at least a silver member to download it. However here is the instructions for the set down.
  • 05-24-2008 7:19 AM In reply to
    Thank you for that Peter. Very good of you.
    I shall give it a try later.
    Luke
  • 05-26-2008 10:16 AM In reply to
    Yes, that did the trick.
    Thanks again Peter Smile
    Luke
  • 01-13-2010 5:50 PM In reply to
    Hello,
    I have same problem with a BG1202, the pickup seems to set down abit to early. Have read the servicemanual but is abit confused, better be safe then sorry, do I access the eccentrik A and B from bottom or from top (via removal of platter)?
    Have only "worked" with BG7000 prior and that had abit more "straightforward servicemode" :)
    Thanx
    MoglesMac
    Sweden
