Latest post 05-29-2008 7:11 AM by Corvin. 4 replies.
Page 1 of 1 (5 items)
  • 05-23-2008 5:38 AM
    • Corvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Australia
    • Posts 124
    Wireless 1 connection
    I have just purchased a 3rd wireless 1 receiver. It will not connect, is there any known problems for a simple connection or is it most likly the product is faulty?
    I have factory reset my receiver and re-connected the original 2 receivers with no trouble.
  • 05-23-2008 12:57 PM In reply to
    • Alex
    • New York, NY
    • Posts 176
    Re: Wireless 1 connection
    Corvin:
    Whoever sold this to you should have told you this, but likely the problem you're having is software incompatibility.  You need to bring all of your wireless units to the dealer and they need to use the service tool to make sure they are all running the same software version or you will not be able to pair the new unit to the older system.
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
  • 05-23-2008 6:56 PM In reply to
    • Corvin
    • Australia
    • Posts 124
    Thanks, i was wondering if it could be a software issue. Ill check with the dealer.
  • 05-24-2008 3:42 AM In reply to
    • pf85
    • Joined on 04-21-2007
    • Posts 145
    Just had to do the same exercise two days ago. All units should go to SW release 2.10
  • 05-29-2008 7:11 AM In reply to
    • Corvin
    • Australia
    • Posts 124
    Thanks, i am just waiting for my poorly performing dealer to get back to me.
    I was promised a response by 4 days ago.
