1st March February 2012
Latest post 06-08-2008 7:31 PM by max124. 12 replies.
05-21-2008 3:49 PM
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
How are you trying to connect the cable Box? By Scart or RF connection/ Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Craig
- Posts 4,855
Have you assigned the Scart connections in the Menu? For example Scart 1 as DVD and Scart 2 as SAT Craig
max124
- Joined on 05-18-2008
- Posts 8
thanks for your help - we've been away and went back at it again to-day. we have av2 set to decoder and av1 set to vhs1 i think - the dvd is actually a sony dvd/vcr combo. also the volume control isnt coming up on screen any more and mute doesnt work - could the remote be faulty. the very first thing we did was put new batteries in.
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Assign tv programme #1 as decoder needed, then turn to programme #1, should go to the cable box then. Be sure to use a fully wired scart lead! Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
kallasr
- Posts 1,077
And if you delete all tv channels except for #1, pressing tv will always go to channel 1 thus using the cable box. Ralf
max124
- Posts 8
hi ralf - how do we clear what is stored there. we have as follows. 1 ............ 2 bbc2 3............. 4 channel 4 5................. and all the rest are blank. we have allocated av2 to decoder and av1 to vhs - non b&o as the vhs is sony. thanks
kallasr
- Posts 1,077
trying to recall this from memory... go to the channel you want to delete, go to the second tuning menu, move cursor to STORE, change to DELETE using the down arrow, and GO. Ralf
max124
- Posts 8
ralf - we have success - pressing tv then sat on the remote gets us in to the cable box - then use the remote supplied by cable co. fantastic picture ! - hopefully all will continue ok - will post again tomorrrow. thanks again
Page 1 of 1 (13 items)
