Latest post 05-21-2008 4:54 AM by Alex. 7 replies.
Page 1 of 1 (8 items)
  • 05-20-2008 4:19 PM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Beolab 7.2 / Beolab 7.4
    Hi there
    What are the differences i have beovision 7 with Beolab 7.4 underneath but im not sure i am so happy i think beolab 7.2 will look so much better expecially when i go for wall mounting or table mounting.
    Does the 7.2 fit on the same stand (floor motorised one).
    What one is better and finally does anyone wanna swap.
    Seanie
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 05-20-2008 5:12 PM In reply to
    Re: Beolab 7.2 / Beolab 7.4
    Hi there,
    It sure is easier fitting the 7.2 if you decide to put the BeoVision 7 on a table..:)
    The 7.2 fits on the same stand but you need a different bracket to mount the speaker on. When you go to the dealer make sure to tell him whether it is a BeoVision 7 - 32 or BeoVision 7 - 40 you have. The brackets are different..
     I would personally always go with 7.4 when having other speakers connected to the tv. If no others speakers are connected 7.4 will not sound very good, since it is a mono speaker.
    The 7.2 is a stereo speaker and plays awesome. Especially  when no other speakers are connected. What colour is your 7-4?
    BMGHB
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 05-20-2008 5:18 PM In reply to
    Seanie,
    Hopefully I can answer your questions. The biggest difference between the 7-4 and the 7-2 when not trying to over-complicate, really comes into play with how you use your TV. If you are putting the display on a surround sound set-up, then we would recommend a 7-4 as it is optimised both with cabinet and acoustics to perform for voice prodomently (what most people end up lacking a bit when used lets just say with a pair of BeoLab 4000's). The 7-4 is not limited to voice and is a great performer in both surround or by itself, but I have found if you are NOT going to put the BeoVision 7 in a surround sound set-up, in most cases you will benefit with a 7-2 more. The 7-2 will give you a true stereo left and right, where as the 7-4 is more mono (remember for voice). I think the performance of the 7-4 sounds so good because of the ALT lens which projects the highs more uniform and even in the room, similar to the BL9 or BL5. But in a stand alone set-up or even in a 3 channel mode you will receive better performance with a 7-2, unless your left and right are BL9 or BL5.....I know so many twists and turns:)    The stand is the same stand, however if you choose to go with a different speaker option you will have to purchase the holder for that particular speaker. If I remember correctly the BL 7-2 is a recessed flat type holder, where the BL 7-4 is lip hold type. You should be able to use the same power link jump cable and power supply though:)
    BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
  • 05-20-2008 5:39 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    hi there
    thanks for your input and i do havea  surround set up, i just wonder if i wanted to put the tv on the wall or on a ssmall stand as i have really gone off the tall motorised stand as all you can see it wires even with the sock.
    does anyone have pictures of the tv on a small stand or wall with a 7.4 where can the 7.4 go as it will just look sillt on the wall i think????
    Help
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-20-2008 5:41 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    my 7.4 is the normal silver colour and the stand is also silver
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 05-20-2008 6:59 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The 7-4 makes the BeoVision 7 look lighter, whilst the 7-2 (or 7-1 in the case of the 32" BV7) can make the TV look 'heavy' and actually a little larger than it really is.
    I'd recommend the 7-40 wall bracket if your wall can take it! Excellent piece of engineering and very very cool when it's working. You can mount the 7-4 to the wall bracket too, and the BV7 display will angle vertically independently to the 7-4 which is on a fixed plane. They both turn left/right with each other though, and fully motorised!
    Sonically, when using other BeoLabs in the setup, especially BeoLab 3s, 9s or 5s, the 7-4 will give very noticeable sound improvements!
     Weekly top artists:
  • 05-20-2008 8:03 PM In reply to
    Original B&O wall brackets
  • 05-21-2008 4:54 AM In reply to
    • Alex
    • Posts 2,990
    Just like that! I prefer it with the 7-4 underneath personally, but it's all up to you, not us.
     Weekly top artists:
