Latest post 05-21-2008 2:12 AM by Roger. 4 replies.
Page 1 of 1 (5 items)
  • 05-20-2008 10:32 AM
    BeoVision 7-40 Mark???
    Hello everyone,
     Please Help! I've got a second Hand BV 7-40 in my sights...
    Type no 9351
    Item no 1816970
    Serial no 19071684
    Is this BV 7-40 Mark I or II?
    Thanks in advance,
    Pedro
    Filed under: , ,
  • 05-20-2008 10:50 AM In reply to
    Re: BeoVision 7-40 Mark???
    Type 9351 is Mark 1
  • 05-20-2008 11:16 AM In reply to
    Yes,
    it is a Mark I, one of the later ones though.
    If you are looking for a Mark II, search for type numbers 936x and above.
  • 05-20-2008 3:27 PM In reply to
    Thank you, guys...
  • 05-21-2008 2:12 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    There is a major difference between mk II and III, but I would rather focus on the "milage", the overall condition and the price if I had to choose between mk I and II. I find it hard to tell them apart... and I used both the mk I and II before I moved to plasma.
    Roger
