Latest post 05-22-2008 4:51 AM by Thomas. 4 replies.
Page 1 of 1 (5 items)
  • 05-20-2008 6:39 AM
    • Thomas
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Norway
    • Posts 85
    Error msg when launching beoplayer
    I am getting an error msg when trying to launch beoplayer (It happens after I installed on a new laptop running XP).
    Msg says:  "Not registred - Your beoplayer V4,80 will not work".
    (I see the window for registring flashing by, but is like a pop up blocker is closing it")
    I have switched off the firewall + I have no pop up blockers active.
    Anyone with any ideas ?
    Thomas
    7-40 Mk3, Beo5/Beo4, Avant32DVD, BS3K, PentaIII, BL4K, BL Active w/BL2500, Avant28CTV,Beoport, AppleTV, 2xBC6K
  • 05-21-2008 9:06 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Re: Error msg when launching beoplayer
    Thomas;
    I had the same experience with a new MAC Powerbook laptop, also running MS XP on one side ( which is very hard to find these days ). I use AVG on the PC side of the HD but I don't recall any issues with the firewall or antivirus.
    In my case, I took the old version of Beoplayer off ( using Add/Remove ), rebooted, reinstalled the new version of Beoplayer off the B&O website, rebooted, and then re-registered. . I lost no music, photos, or video files, as I use the XP Media Centre version, and load those items first via Mediaplayer. The new Beoplayer simply scanned and loaded everything including the icons from those files.
    The MAC is a great laptop, with some fantastic programs, but I enjoy Beoplayer music and radio through our main PC / ML Beosystem, and keep it consistent with the MAC.
    Let us know, as I hope this is helpful and successful for you.
  • 05-22-2008 3:43 AM In reply to
    • Thomas
    • Norway
    • Posts 85
    I have alredy tried to remove beoplayer with windows add/remove tool, downloaded (And saved the install file on my c drive) and tried a fresh installation, but so far no luck :-(
    I am a little worried as I plan to buy the beoport and I hope i dont get the same problems with that.
    Thomas
  • 05-22-2008 4:05 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Hi
    I had the same problem after install Internet Explorer 8 Beta. No windows popped up to register, and i have Beoport. I came back to IE 7 and everything with Beoport/Beoplayer worked fine again. Maybe you have IE 8 Beta installed?
    Quim
  • 05-22-2008 4:51 AM In reply to
    • Thomas
    • Norway
    • Posts 85
    Hello,
    I am using explorer 7.
    Thomas
