Latest post 05-22-2008 3:03 AM by SWISS_2. 13 replies.
Page 1 of 1 (14 items)
  • 05-19-2008 3:41 PM
    • yeabo
    • Not Ranked
    • Joined on 04-01-2008
    • Posts 11
    Beolab 2000 vs Beolab 3500
    I want to add a link speaker in my utility room (Wife wants music when ironing........)
    Beolab 2000 - on ebay £200-250 (discontinued)
    Beolab 3599 - £700 - £750 - not sure price as new
    A friend of mine said go for the 2000 because doesn't need a remote (I don't think this is a major problem).
    What in your opinion is the best value for money and what are the pros and cons of each speaker?
    What about adding a ceiling speaker and a link eye?
    The max. I would spend is £1000 (cheaper to buy new shirts for the next few years) - are there any other options?
    Thanks in adbvance for any useful advice
    Regards
    Yeabo
    Filed under:
  • 05-19-2008 4:23 PM In reply to
    Re: Beolab 2000 vs Beolab 3500
    The 3500 provides far better sound quality than the 2000 although neither is brilliant IMO.
    Regards Graham
  • 05-19-2008 4:32 PM In reply to
    • yeabo
    • Not Ranked
    • Posts 11
    Can you suggest an alternative?
  • 05-19-2008 4:46 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    How about second hand BL4000's (~£700 - £800)
  • 05-20-2008 4:49 AM In reply to
    • Beolab1
    • Top 500 Contributor
    • Joined on 08-04-2007
    • Hong Kong
    • Posts 232
    • Gold Member
    I have two beolab 2000 in the bathrooms. I really like them a lot. The mini control panel is very practical, they have many placing options and can also be used with a remote. I find the sound very impressive for such a small unit and it can play really loud if wanted, without distortion. The price tag is also quite reasonable for B&O standards. For small rooms they are perfect.
  • 05-20-2008 5:56 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Just to make your choice even more difficult...
    I got a Beolab 3500 in the dining room (see one of my post for pictures), perfect for background music when we have guests.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 05-20-2008 5:58 AM In reply to
    • kallasr
    • Posts 1,077
    Got mine for 300 Euro/240 GBP from ebay... a real bargain... but sometimes you just have to be lucky!
    Ralf
  • 05-20-2008 2:32 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Both are good speakers, but for your Utility-Laundry Room application, I would suggest the 2000.
    Easier to clean, robust metal construction, can be mounted or freestanding ( moved as needed ), hand or remote controlled, and is ML linked to certain B&O systems.
    I have both in upstairs bedrooms, serving as music, radio, Internet, and SKY TV sound extensions. I one takes a Beo4-Beo 5 along upstairs, it does provide a " Pathway of Sound. " The speakers continue to supplement the recent addition of BV-8, which has very good sound.
    Pulling the ML cable is easy, but making the custom lengths and junction box connections required Ye Olde Flyfishing magnifying set for 2 days, and a little patience. Perhaps you will be fortunate and able to use the stock ML cable connectors available through B&0.
    I hope this is helpful.
  • 05-21-2008 7:07 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Another useful nugget of information is that BeoLab2000 can be activated by the volume control on BeoCom6000.  If the speaker is in standby mode and you turn the volume wheel on a BeoCom6000 handset, the BeoLab2000 switches the Master on to the last thing it was doing.
    As far as I know, the BeoLab3500 doesn't do this.
    Given where you say it is being used, I would go for the BeoLab2000.
    Opman
  • 05-21-2008 7:10 AM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    I'm a fan of both - the BL2000 is more flexible overall, and also cheaper. However, you can't buy them new any more, so the likelihood is that the garuantee is either much shorter or gone alltogether.
    BeoLab 3500 is far more discreet, sounds better and will come with the guarantee. However, doesn't offer the same hands-on-control as the BeoLab 2000, which I love! I'm also a sucker for the BL2000's design.
     Weekly top artists:
  • 05-21-2008 8:05 AM In reply to
    "Another useful nugget of information is that BeoLab2000 can be activated by the volume control on BeoCom6000.  If the speaker is in standby mode and you turn the volume wheel on a BeoCom6000 handset, the BeoLab2000 switches the Master on to the last thing it was doing.
    As far as I know, the BeoLab3500 doesn't do this."
    The 3500 will switch on using the volume switch on the Beocom 6000 and the AV control on the Becom 2500/1600.
  • 05-21-2008 9:15 PM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    I just learned something new, so a question to the experts:
    Do you think this would work with the other Beocom models ( as they all have A / V buttons ) ?
  • 05-22-2008 2:49 AM In reply to
    The Beolab 3500 is a very good product particularly for background music when you are ironing.
    It WILL switch on using the A/V and volume on the Beocom 6000 and with other beocoms
    Opman:
    Opman
    Regards Keith....
  • 05-22-2008 3:03 AM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Keith, it sounds as though you speak from experience.
    Can I send you my Tattersalls: The local laundry here sprays too much starch.
